protoj · Tuesday at 18:48 1 day
hey folks
short one on air filters : I know you get this " annoying" goose honk sound from the recirc valves when using a K&N cone type filter , but is it possible that you get a quieter , low toned "goose honk" when using a K&N drop in style filter ? ....kicks in at about 5000-5500 rpm.
Maz
