Well a rather annoying twist in the tale. Installed the crank the other day after completing all pre assembly prep. Everything seemed ok bar a slight bit of clearancing needed on the girdle plate. Took everything off and found a whopper of a scratch on one of my main bearings. Annoyed doesn’t come close!
I know the block and crank were crystal clean so I can only assume that my old pot of assembly lube had become contaminated with a bit of grit or who knows what. What are the odds?!?
So, yet again, a thorough clean of block and crank before sealing away on clean bags while I await new bearings to arrive….. and a NEW bottle of assembly lube by @torcousa via @nimbusmotorsport
By
nickz32 ·
Well I have finally started to take my dash out.
I have given up outside for today, come in to build my gauge cluster.
Following issues so far:
Cant get the bloody hazard switch connector off
Fog light switch has been bodge soldered by prev so im gonna have to cut the wires.
Cant get the stpuid connector off the internal temp sensor
Cant feel a screw head in the rear of the steering wheel to get the cover off, to get the wheel off.
Can anyone help with these?
Can of worms lol!
