Me again.
So I have two questions:
RobHowl ·
Hi everyone, :rofl:
Have a 300 TT Jap 93 – Doing a 300 degree fuel rail upgrade with 555cc Nismo inj and chip
Confusion about vacuum pipes on the Passenger side – if poss can you send me a pic?
Not sure about which goes to intake phelum, Back of air bal bar and vacuum on fuel gallery.
Cheers,
Anto
