Manual boost control guide
Is there a setup guide someone could post to put a bleed valve onto the tt anywhere on the net, just to save me time etc.
Think i could just go to the plumbing shop on my road and get two bleed valves and bleed both turbos individualy. Any ideas?
Thanks paul but they are boost jets which i already tried..
im also wondering will i neeed to unplug the wastgate solenoids?
get a manual boost controller rather than a bleed valve, there is slight difference.
yeah i will get a good one but till then il do all the conecting work wih hoses etc then when i get one il just put it in its place.
Where are the solenoid connectors located as i want to disconnect them. pics would be good :)
down the side of the engine with a brown plug around the suspension area.
ah thank you..... and there are two? on each side at the same place?
whats wrong with the boost jets?? better than a bleed valve IMO as no metered air is being vented
if i remember right, my old car did this and it was cured by fixing the boost leaks i didnt know i had.
and how can i find these boost leaks if i have any?
Haha thats cool il give it a go when i wake up.... nice one retro ;)
