Automatic gearbox fluid change.
I plan to change the auto box fluid over christmas so i need to order the bits to do it now.I've read this http://www.300zx.org.uk/tech_09.htm so i know i need an oil pan gasket but do i need the "o" ring on the strainer pipe or anything else ? It also says use mineral turpentine to clean the strainer, is this turps from B&Q you clean your brushes with ? :D
You dont need to change the O ring if its not damaged and I used a couple of litres of petrol to clean the strainer. Had no problems.
