O2 Sensors
HI ALL :hyper:
AM SUFFERING HESITATION AT STEADY SPEEDS, UNDER NO LOAD AND REATIC IDLE, PULSING UP AND DOWN BETWEEN 600-1400 :rant:
TPS IS FINE, INJECTORS FINE, COIL PACKS FINE, TEMP SENSOR FINE AIV FINE. :D
AFTER SEARCHING THE FORUMS I HAVE COME TO THE CONCLUSION THAT IT COULD BE THE O2 SENSORS :D
AM LOOKING FOR ANYONE IN THE SUFFOLK/NORFOLK AREA THAT COULD DO THIS FOR ME AND WHAT SORT OF PRICE WILL IT COST :D
MANY THANKS
ALAN
i would first get a diagnostic to confirm your suspicions mate. There should be someone in your area that would be will to give you 15mins of their time to test it on a conzult.
HEY GIANT
HAD A CONZULT A FEW WEEKS AGO AND COME UP LEAN ON O2 SENSORS AND NOT FLUCTUATING BETWEEN LEAN AND RICH AS NORMAL
THOUGHT THIS CONFIRMS O2 SENOR/S GONE BAD
CHEERS MATE
ALAN
Mike Feeny at MJP in the traders section can sort you out with genuine Nissan 02 sensors, as for fitting in your area I don't know sorry
from when i had a conzult done which showed my O2 sensors were kaput the tell-tale sign was that the values stayed constant when the throttle was blipped when they should of been racing up and down. No movement when throttled means the sensors are dead (i think).
