Damn leaks
I keep getting a very wet drivers seat. There is a leak some where and i can't find it. So annoying.
incontenance pads mate :rofl: :rofl: :rofl:
Or don't drink for several hours before you drive. It's not your fault. It's just the exitment of putting your foot down. Youll grow out of it.
Yours Margary
try checking the rubber block next to the front targa drainage hole. at one point it wold have been stuck down... try puttng some silicone sealant or something in there.
haha my willie keeps leaking.
I will check those rubber block thingys if i can work out which ones they are, don't suppose you have a pic?
I did atempt repairing the leak but not fully assembling the targa as i wanted to retrim it, e.g. not putting the end caps back on and the fabric thingy doo dar but i don't think that is the cause that being missing not unless the end caps are actually functional.
This is the best pic I could find
You'll see a small drainage hole (About 8mm dia) and next to it a large block of rubber stuck down to fill the gulley.
Oh that's brilliant thanks, i know exactly which bit you mean now. I i remember correctly that is all flappy and loose. I will get the silicone gun out on that tomorrow if it's dry out there.
Thanks.
I siliconed it up and i still have a leak.
i gave it at harsh spray with a pressure hose to see where it is and it appears i have 2 leaks i think it's coming in on the join where targa rubber sits with the rubber which wraps around the targa and down the pillar on the corner.
Really starting to get annoying as it's soaked.
