Dead Injector!
The injector on number six cylinder on my Zed has given up the ghost, apart from the following what else should I do when the plenum is off;
1. Plenum bypass.
2. EGR removal.
3. Hoses connected to fuel rail.
Any other advice will be gratefully appreciated!
I am guessing but if one injector has gone are the rest in need of a good looking at?
Will be replacing all 6!
Is it definitely an injector fault?, or is it an electrical problem? i.e. Connector fouled up?
get new connectors for the new injectors while youre there. they will prob be all green & corroded!
New connector fitted on Saturday, there is power to the injector but when checked with multimeter it is showing as an open circuit the garage concerned assures me it is the injector (fingers crossed).
I had a similar problem, although in the end it turned out to be at least partly an electrical connection on the injector. But I did the following at the time :-
Removed the plenum, had it blasted and chemically cleaned
Removed the EGR
Bypassed the throttle body heaters and removed all the pipe stubs
Changed all the electrical connectors incl. injectors, coilpacks and idle valve etc
Had all injectors cleaned and checked/calibrated.
Changed PCV's
The engine has never run so smoothly since all that was done - I put most of it down to the electrical connections.
:( another problem, you aint had much luck with that car so far!, hopefully the slight misfire youve been getting is down to the injector starting to go and you get back to smooth running soon!
I hope so, getting it done at Hypertech if I can get someone to sell me the parts :headvswal
Are you going for new, or trying for a set of used.
