Plenum removal - replacement parts needed?
What parts do i need to replace when removing it i.e gaskets etc ???
Getting it polished ;)
If your taking the plenum off you will obviously need a new gasket, but I would also definitely consider changing your PCV valves and pipework, especially if they are original, and for a couple more quid perhaps an EGR bypass and a topend water bypass. You should also think about replacing all the water pipes at the rear of the engine that you can then get at more easily with the plenum off which would not cost a lot of money but can certainly cost a lot to change if they leak later.
Upper-lower intake gasket 14033-30P02
2 EGR gaskets 14719-30P03
2 TB gaskets 16175-30P70
1 IAV gasket 23785-40F00
Balance bar o-rings 2 x 14033-30P05 and 1 x 14033-30P06
Plus PCV valves and hoses and 3m of 8mm ID silicon hose to do a TB coolant bypass
Where can you get them from andy?? will be doing mine soon
whats all this for?? "PCV valves and hoses and 3m of 8mm ID silicon hose to do a TB coolant bypass"
Might as well do it while it is all off.
FIxed my idle/ choke problem/ heater, It was the temp sensor you mentioned.all green and gumed up
cheers buddy :D
Out of interest where are you getting it polished and how much if you dont mind me asking ?
