Hubs
Can anyone tell me what hubs are needed for a Nissan 200 to convert to 5 stud. Would I be right in saying that either NA or TT front hubs and NA rear hubs are required as I know there are differences between the rear hubs but am thinking the fronts will be the same.
ย
Cheers John
Rear hubs from the 300zx na, are all you can use from the z, you're best off with a set of hubs from a s14/14a
You can use the tt alloy hubs if you press out the hicas balljoints and replace with poly bushes .these hubs are lighter than the cast iron hubs of the s14.Not sure about drive shafts thought i thinj the zed 32 drive shafts are thicker than s13/s14.
Fry what should be used for the front hubs then?
ย
Taff the NA splines on the drive shafts are smaller than the TT ones.
ย
Cheers John
