Pulling to the left
I wonder if anyone can point me in the right direction,
My car pulls to the left, i have had the tracking done, checked tyre pressures e.t.c. The left hand boot on the steering rack is torn and their is a metal type washer floating around on it.
Sorry if that is a bit vague but maybe someone will know what im on about.
ANY SUGGESTIONS VERY WELCOME
thanks
thanks
going to keep an eye on this thread as ive done all the above and mine does the same :confused:
When the tracking was done did you have a four wheel alignment.? And is the steering wheel straight.
yes i had all 4 done, its only from the front and you can see that the left wheel is slightly out
I had that washer thing floating about on the rack arm when i changed my rack gaiter ,did you find out where its from .I just left mine there couldnt see where it was from.
thanks
hi james
mine is the same, pulls slightly to the left, had all wheels lined, tracking is spot on, no wear on inner or outer of tyres!!!!!!!!! :confused:
my tyres are wearing evenly on the front!!! :confused: :confused:
someone told me if you fit oversize alloys, this can make the it pull to the left 'cause the slight camber on the road for water drainage.
i have 18" ultralites. :D
hope this helps
alan
hi james
hope this helps
alan
you could be right here bud because mine dont do it on my uk rims only when i fit 17" :confused:
thanks guys back to the drawing board lol
regarding the above posts you can try a stretch of road on an earlly sunday morning and drive on the other side and i bet you it stops pulling to the left :confused: because iff i drive on an opposite camber it goes
ball joint on the way out? wrong sized tyes to wide for rim ? warped brake disc?
no no no ;)
no no no ;)
Then sir your car is posessed and need to be burnt :p
one last try worn steering bush
no---click---flick---BOOM
PROBLEM SOLVED all is quite in Z land :mac1:
