Hi..
i have a 90 300zx tt manual i got engine rebuild some weeks ago
car was runing fine until it started doing the following:
wend pressing the gas pedal revs goes down and it just cames back up afther a while
but if i press the gas pedal slow it will start going up but just up to 5k
ive check the ecu codes theres no errors
:headvswal
does any one has any ideas? were fault may came from ?
tks in advance
ok since seams no one had this problem before and no one knows whats happening :(
any one whit a 300zx tt around heathrow ? so i can check my one ?
:confused:
Check the temperature sensor connector for the ECU - 2 pin connector on upper pipe at front of engine.
Then check all coilpack connectors and injector connectors are secure. Look in FAQ section, engine, there's a post "engine by numbers" if you are unsure where any of these are...
