protoj · Tuesday at 18:48 1 day
Hey there
Just joined and while saying 'hello' in the general forum, just thought I'd say a more localised 'hi' in my local area. We are pretty close to Hailsham and just off the A22. Not sure if there are any members round here though as I have rarely seen a 300 down here.
