bad vibration under my seat and glovebox
as above i just had my new auto box fitted it was fine before box went but now i have a really bad vibration coming from under the seat and glove box all through the bottom of the car can any one tell me what this could be and am i safe driving it while it is doing this cheers
prop vibration. misaligned prop or bearing on way out
will i cause any problems if i drive it like this cheers
could it be something as simple as the bearing housing hasnt been tightened up properly??
But if your getting bad vibration.....i wouldnt drive it. You could end up buckling your prop shaft. But thats just my thoughts
yes the problems you are encountering. premature wear of the centre bearings possible damage to gearbox or diff.if left long enough. take it back to where you had ift fitted and get them to sort it. prop misalignment most likely cause so when you had the box fitted they didnt fit it back on correctly
even a prop bolt missing would cause vibration
could also be sagging gearbox mount. They look OK but if it bottoms out makes a lot of vibe.
I had transmission mount and centre bearing replaced as used to vibrate under my seat
took me a while to fix it, as it made the gear knob rattle too :headvswal
though in the end it drove me mad.... depends how much rattling you can put up with lol
Had a new clutch fitted on my old n/a and whne I picked it up she vibrated like hell at anything over 30 mph. Apparently they had put the prop shaft back on 180 degrees out. A quick change and she was fine.
My money is on the spacers between the centre bearing and the car - if you don't know what you are doing these get put back as washers rather than spacers (dont it myself!) - 10 min job to fix.
Good luck
Jack
Yep, deffinately prop relatated, could be any of the above, prop out of balance most likely, did you mark it when took it off?
Either the rear 'box support is fubar, they've not put the prop back on with the correct centre-rear section alignment or the spacers have been used as washers instead...
