Manual conversion time anyone
Good day everyone,,, I was wondering if anyone out there would like to do a manual conversion for me i have all parts from my donor car (still fitted), driving the auto at the mo with only 2 gears :rant: with no auto box faults showing so box must be knackered, please help anyone i have all parts etc just no room to work to do the conversion........free :duffer: :duffer: :duffer: to any takers lol......cheers Jay
to be fair bud ...it's a lot of work ....and if you have, to strip the Doner car too .... :eek:
then your looking at about, a day and a half's work..!!!! more like 2 day's ,if we do it on your drive ..... :headvswal
your looking at £400+..or (£600/700 just for the labour for a garage)
wozza ....
Hey guys,
I would do it on my yard but it's gravel and space a bit of a premium and trusting anyone round here to do the conversion is a laugh really, i would like to do it myself with a little help of course. i am planning on stripping the donor car first im half way there already, just cant get engine lift in my yard its that tight, + i got 4 cars parked bumper to bumper lol..... just cant win at the mo.....
  • 5 weeks later...
Well iv'e got myself a garage now so im going ahead with the conversion over the next 2 weeks, not really looking forward to it but hey the auto box is dead so must be done, any tips or tricks while doin theis would be great.
do a search bud, should be loads of info
mail me @ greg300zx@hotmail.com
if you need any info through the operation ;)
Make sure you have everything required otherwise the job will obviously take longer. Try and get a custom hose for master-slave cylinder! saves running the old crap pipework which can be fiddly and the bleeding part. heres a list of parts you need off the top of my head
gearbox ;)
fluid
clutch(new) inc spigot/release bearing.
flywheel (new or skimmed)
clutch bolts &washers
flywheel bolts
rear transmission plate
gearbox bolts especially the longer one @5 oclock
MT propshaft
rear crossmember should be on gearbox
clutch booster TT
clutch pedal
slave cylinder
master cylinder
brake pedal (or cut old one to size and use MT brake pedal rubber)
hydraulic pipework or get one made with the correct fittings from goodridge)
x2 rubber boots for transmission tunnel
gear linkage and shifter new bushes preferably
gear gator
gearknob ;)
Tip if your doing it from home, on my 200s14a i cut the brake pedal down and fitted rubber cover from a manual car, whilst there i removed the plate between firewall and cabin to fit clutch pedal, on a 300zx this is mearly tacked on so can be pryed away, the 200sx has to be cut to suit :shock: !! when you fit the booster and clutch pedal you can still drive the car around with 3 pedals whist its still auto, advantage saves you a job when it comes to it! as to be honest the only **** ass part is a)removing the auto spigot from the back of the crank. And fitting the booster and pedal! the rest is no differant than doing a clutch change!! the only other thing to do is bridge the wiring to start the car, you can then figure how to wire up the reverse lights later!
hth greg
Thanks Greg, Certainly will get intouch if i have any problems, I have all parts exect clutch and spigot bearing so far. lol oh and rear main seal...
