speedo question
Hi all
my 112mph limiter has been removed as i checked it out on track mon with a gps. But my speedo is still running in KM??
I havent removed the limiter i think it was done in japan?? so does anyone have any ideas how to get the 180mph clock in as i dont want the 110mph it looks daft
I had the same problem when i had my MR2. I tried a converter chip but it never worked so i had to buy some uk clocks
Any ideas??
cheers
A UK chip and UK clocks is the way I went in the end.
If the limiter has been removed then I think I am right in saying that it will have been chipped and hopefully socketed. This will mean that a UK chip should be easier to fit. AndyP can point you in the right direction about this.
The converter changes the signal to the clocks to mak them think you are going slower than you really are I believe. I had major problems fiting one of these as well so went for a set of UK clocks. Hope this helps.
Darrell
