I am having a problem with one of my headlamps not working which is causing the other side high beam to come on.
I have a UK car with the dip-dim system and think this is either where the problem is or i can find where the problem is from here.
Has anyone had a similar problem?
I have seen threads where people got a dip-dim bypass instructions from the Zcentre when buying HIDs. Would someone be able to tell me about these instructions?
Thanks.
Tom
if i recal the dim dip unit is under the n/s front wing
syko
The location diagram in the manual isnt specific enough.
If it is under the near side front wing then yes it will be a arch liner removal job. But from the looks of the diagram it could also be on the inner wing in the engine compartment, or even behind the front passenger side kick panel!
Sorry I can't be of anymore help.
Dave
