Injector examination
Lasty300 has agreed to kindly come over and help me get my plenum off as I'm a noob ( :hyper: ) but neither of us is quite sure what to look for re the injectors! My ECU gave a code 45: Injector leak. Should I just change out the injectors or is it likely to be something minor that will just require tightening/securing??
Does anyone have some kind of checklist that we can work through?? We're hoping to do this on saturday so would be good to get hold of something before then!
Cheers... :bow:
its a bit of a bugger the first time, did my first one last week, theres lots to move out the way, but be patient and you'll do it, its also a good idea to keep every thing tagged or marked, or definitely now what connector is what and where it goes to. If you do take it of, by pass the water pipes under the plenum, fairly easy job. Cant really help you with the ecu codes fella, If its how it reads and the injector is infact leaking then you,ll have to have them out. good luck
