side lights?!?
Hi everybody,
My side lights (front positioning lights) have packed in. I have checked the fuse in the footwell and that looks good.
All other lights are working fine.
Is there a relay under the bonnet or any other fuses for the side lights that I need to check?
What should I be looking for?
Check for a carroded earth by eathing them direct to the chasis
Have you sorted the headlight aiming out?
I only ask because you might have disturbed something doing it.
Have you had a look at the online manual?
If not you can download it from here.
http://www.4shared.com/account/home.jsp;jsessionid=6676FC89CB5CED32606A11E91E9A162A?rand=0.14954343578426843
Darrell
Haven't touched the headlight yet, still waiting for the part to turn up.
edit - that link worked but has now stopped for some reason! WTF?
don't think it is a corroded earth either (just a hunch).
Is there any fuse or relay I should be looking for?
drivers footwell, on side wall right up next to accelerator. remove pannel looks like:
think it's the fuse marked clearance ilumination
[sIGPIC][/sIGPIC]
Yep, thanks Ian,
tested that one and it is fine.
Anyone else?
