nismo thermostat
an extra .1 bar will reduce temps, In a cooling system, a higher pressure equates to a higher boiling point for the coolant. Higher coolant pressures also transfer heat from the cylinder heads more efficiently
ooops, suck back time, well spotted that man,
ahem
I advise a nismo rad cap as ( cut and paste from above)an extra .1 bar will reduce temps, In a cooling system, a higher pressure equates to a higher boiling point for the coolant. Higher coolant pressures also transfer heat from the cylinder heads more efficiently
I wouldn't bother with the thermostate. I have one and it is really one an advantage on track days. Other than that it just means your car is running about 70 C.
