- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
As I posted before, my ZED chucks its water out when I give it some stick. I thought the system was pressurizing from either a crack in the head or block.
BUT, today I got round to running it up and putting a Block Tester on it, this proved negative, No gas in the water. :hyper:
Now, I've been wracking my brain and realised that this problem started after I fitted a lightened and smaller underdrive pulley so the pump isn't turning so quickly. the engine runs fine, sweet as, no misfire or any other tell tale sign of a crack in the cylinder area.
Has anybody else had cooling probs due to underdrive pulley or a weak water pump?? The temp gauge does not go over halfway and its never shown as overheating. I can leave the engine idling for hours and it never chucks the water out or gets hotter than normal temp, incidentally the fan doesn't come on either, I can run it and rev it, still nothing, but as soon as I run down the road and put it under load the water comes out of the expansion tank. Could this be due to the extra heat from the turbos, load and the fact that the water isn't moving quick enough?
I've though of a blocked rad but this gets nice and warm all over. So any experiences of waterpump trouble guys and girls.???
Jase
