Coil pac conx
How the hell do you get these of without knackering them, i can only get one off, lol the rest are stuck fast. any tricks i should no about.
oh and what size are the plugs on these, 16mm???
There is no trick to taking them off without breaking. No matter how carful you are they are probably going to break. Years of heat and then cold and then heat makes the plastic more brille that a 90 year old with a zimmer frame.
Buy 2 sets of pulsar ones (4 per set) which will fit, soldier them in place and you will be good for another 5 - 6 years.
Yeah you can get them direct from them or from the Z center. http://www.zcenter.co.uk or even MJP check the traders section on here as I'm sure they will all be cheaper than nissan.
