In memory of Mandy
Subaru sounding Z
Wednesday morning was freezing; my Nissan had troubles starting. When it finally fired up, it seemed to be running on 4 cylinders (sounding exactly like a subaru). I risked it and took it for a drive, then the cylinders started to work again once the car had warmed up fully. Has this happened to anyone before?
Also, £10 of fuel only does 12 miles!! Is it the injectors?
Headgasket faliure??? :cry:
Don't say that!! Are you trying to hurt my feelings? :rofl:
No dude! Sorry, don't wanna put the fear of god into you but it just seems strange it goes away when it warms up! Check all your connections are nice and tight and top of your coil packs and your water and oil too! You may just have a slight hairline fail in the gasket but hopefully it's something else!
Na, I was only joking about the feelings thing :) To be honest, if the head gasket goes, i'll only turn it into an engine rebuild job sooner then I thought. The problem is, all the bits are breaking at the wrong time to how I want them replaced :(
Power pack connectors loose or dirty, clean and reset. or PTU?
Ok, I narrowed it down to the fact that those'll be somewhere in my car :rofl: I'll look them up and give that a try if the problem comes up again. Cheers ;)
