HI PEOPLE
CAN ANYONE SHED ANY LIGHT ON THIS PLEASE.................... :D
WHEN I PRESS THE CLUTCH PEDAL DOWN I GET A WHINNING NOISE, LIKE A PUPPY-DOG WHIMPERING!!?????!! :confused: :confused:
I KNOW IT SOUNDS STRANGE!! :confused:
AM I RIGHT IN THINKING THE CLUTCH WORKS FROM THE ENGINE PRESSURE??
IF SO, THAT IS WHERE I COULD BE GETTING BOOST/VACUMN LEAK.
THANKS PEOPLE
ALANZ :hyper:
HI PEOPLE
THANKS PEOPLE
ALANZ :hyper:
i use to have the same problem but mine sounded more like a kitten so cant really help you mate :D
Yep, noise is a Vacumn leak in the Clutch booster.
where is the clutch booster located?
is it in the engine bay or in the footwell?
cheers legrath
alanz
cheers legrath
alanz
engine bay i think bud
ok cheers znut
alanz
Clutch booster is behind the dash, up above the clutch peddel, on the inside of the firewall/bulkhead vac pipes are on the inside of the bay.
Pull the pipe off the engine bay side and block it.
Then you will know if its your booster or not
If it is, get ready to spend a week taking your dash out!
Pipe is about 21mm size, directly below the clutch master cylinder, you cant really see it till you look.
Yep its mounted to the top of the Clutch pedal under dash. Unfortunatly its a pricey part to replace new, and not easy to find used.
No need for dash removal, but you will spend a while upside down in drivers footwell. Undo the 2 bolts holding Clutch master cylinder on in engine bay, and there is one other nut at the very top of the clutch pedall thats sits behind the Speedo, but you can get to it and see it from underneath the dash.
thats great,
thanks for your help people.
alanz
