Me again.
So I have two questions:
RobHowl ·
I was in my Golf, and when i passsed you Beeped, waved and flashed my Hazards!! I nearly came to work in the Z this morning and only wish i had now!
You peeled off at 32 and went up the A470?
I'm TubZ...I pulled up at the lights to give you my card but you were too far back!
