Petrol cap hinge door thingy
The release has gone on my petrol cap door? I need somone to open the door while I hold the release inside the car down, it wont swing upen by itself? any ideas?
Pete
I got this too on the black one.... I look a complete plonker at the petrol station fumbling with it :(
Not had a look as to why yet.... Will do so over next few days I hope.
Just file the pin a bit shorter that locks the flap, works perfect then ;)
I used to have the same problem with the boot release. Not sure if the same solution applies but I moved the lock down a bit so that when you pull the leaver it springs up a little bit and stays released. Don't know if the petrol flap works the same way.
Hope that makes sence.
Darrell
When you say file the pin, do you mean the plastic bit that locks it ?
yes
