Front suspension
Hi all.
I am havig a vibration problem under braking and think that it is the bushes and arms etc. I have had a full set of tein street coilovers fitted so it isn't that and have adjustable upper arms. What else can I replace on the front while the bushes are being done?
A ist woould be great so I can order them.
I fairly certain it isn't the brake disks wharped as they are also fairly new.
Darrell
Do you have the Adjustable tension rods too (lower arms) , as its the tension bushes that cause most front end vibrations.
No only the top adjustable.
So the list is
1. Adjustable bottom arms.
2. Bushs (already got a set)
The Adjustable tension arms repalce the tension bushes with spherical bearings, but I would also look at replacing the Steering rack bushes (the bushes that mount the rack to the subframe), they are a common wear item too.
What about the adjustable front tension rods?
Should I do those as well?
Just looking on smithys web site.
Darrell
Yep as above, Adjustable tension arms = adjustable tension rods
Could be discs, are they drilled?, grooved ?, prone to distort slightly.
but normally only apparent under heavy braking!
Yeh, I dont think I would rule out the discs straight away...unless the problem was eveident before and after the new discs were fitted. Discs can be warped in no time at all with a few hard stops...especially when new and not fully bedded.
Having seen the price of the lower adjustable arms I might get some new disks first. At least I know I will need them eventually anyway.
Cheers guys. Watch this space.
Darrell
