protoj · 16 hours ago 16 hr
This afternoon at about half 4. Red one going westbound at Histon and a grey one overtook me at Cambridge/Milton junction eastbound. All within a couple of miles.
I was in my Black J plate Z.
Good to see some more on the roads, despite the terrible weather.
