Hey all
Engine is out and the garage called with the damage. Center piston passenger side was not fitted properly and come away and damaged the bore and the crank. Also the tubs might be fooked they are double checking in case the oil that spilled out of them has come from somewhere else ...Longshot.
New engine needed or a rebuild from scratch with a reground crank and relined bore. etc etc etc...
:hurl:
Hey all
:hurl:
You might be lucky with the tubs as oil contamination may of come from passed the center piston.
