Hi all,
has any1 got any pics of a chipped ecu! (inside) as ive bought a chipped ecu off a member here but still not 100% sure its been chipped or not.it has a sticker on the outside saying cecil sport and also a sticker saying genuine remanufactured nissan ecu. ive opened up both standard and chipped ecu's but theres not much difference except on the 'chipped' ecu the circuit board thats mounted off the main circuit board is a little bigger than my standard 1. if that makes sence at all lol
regards dan
heres a pic of mine. normally a chipped ecu will have a holder that the chip pushes into as in the pic. hope this helps.
Hi all,
regards dan
Sounds like the type Superchips use - not to say that it is one of theirs of course.
thanx for your help ill have a look again 2moz. does a stock ecu still have 2 circuit boards? because where you see marios chip (above) i have another circuit board that mounted above that???
regards dan
Yes, the stock ECU has a second smaller board that is held in place with four screws and is attached by a white ribbon cable.
