September 26, 200719 yr does the gear shift linkage have to be taken off in order to tilt the gear box when taking the engine out please, sorry if this seems a silly question! Car is an auto TT
September 26, 200719 yr does the gear shift linkage have to be taken off in order to tilt the gear box when taking the engine out please, sorry if this seems a silly question! Car is an auto TT No, I only took the prop off which allows the box to tilt.
September 26, 200719 yr Could you get at the top bolts on the gearbox tho? Yes, if you drop the sub frame (makes splitting much easier) and tilt the engine and box forward you can reach the bolts with a 14mm spanner
September 26, 200719 yr you can access the top bolts from underneath without dropping the gearbox by removing the battery for the n/s and the starter for the o/s. If this fails then no you just let the back of the box down on to a jack slowly without removing the gear linkage !
September 26, 200719 yr Author Thanks Paul, Ive had enough for today as its bloody cold plus I need more plasters and cigarettes, some beer will help too
Car is an auto TT
