Results were
Front
140 150
150 132
150 150
Rear
Are these ok??
Engine was cold, plugs out, engine has been stood for a few months I think.
132 is cutting it fine mate,but ideally 14psi difference at most between cylinders!-that aint'!! :smash:
Did you do the test on the floor with engine out?-all the plugs out?-throttle wide open?
Plugs out, throttle closed, engine out.
try with throttle open, but looks a bit low as manta said on one cylinder in particular, not real bad but worn.
I was worried someone would say that, I've put the bell housing back on the box in the car :smash: Would the result be a little higher with the throttle open? The engine is only a tempoary one I'm putting in while I build a new one
i was going to say, bung it in if its a temp one, if the results were less than a hundred per pot i wouldnt bother!
im driving a courtesy car whilst my company car is in for some work, whilst driving it home it was missing like a *******, so checked all leads, removed plugs and tested it cyl 4 has baely no pressure LMAO 140k mile ford though would explain it, i told the company its not a ****ing courteous car!!
erm with all the plugs out, the balance bar is off so NO NEED to open the throttle
