I want to get a new system that's a little fruiter/less restrictive than standard can i use a turbo system on an N/A and can anyone reccomend one?
IS it a LWB or a SWB. 2fast2cool on Ebay do manifolds and decat pipes in stainless and they are top quality and only £129.00 for manifolds and same for decats. you do need to block off the O/S Lamber on the headers and put it into the top of the decat pipe, but my local engineering shop only charged me £20. If you have a LWB they also do a full Cat back system for about £200 in Stainless and very good quality.
If you have a SWB I have a full cat back single exit Alunox system with wideband lamber boss, but it is loud and won't win favour with the nabours
we use a company in Yate called infinity exhausts and a few customers have had them fitted and they are only just round the corner from you so give them a bell and see what they can do !
otherwise a mongoose or something similar would be nice !
You can use the standard Nissan TT exhaust on an NA. It needs the restrictor rings removing (easy job, screwdriver and hammer) before you fit it. It has a smaller centre box than the standard NA system so sounds a bit 'fruitier'.
Watch out for non-standard TT exhausts on an NA as their design dosn't suit a normally aspirated car - and it'll be too loud as you don't have 2 turbos acting as silencers.
...and of course you can pick up standard Nissan TT exhausts relatively cheaply...
Good luck
Jack
