protoj · 33 minutes ago 33 min
hi, has anyone got some form of guide for fitting one of these, its a Blitz SSDC R spec boost controller, I was hoping to use the write ups in the FAQ section which has fitting a greddy controller as a rough guide but the links / pics dont seem to work anymore, my car is a 1993 UK TT Auto
Any help greatly appreciated
