protoj · 8 hours ago 8 hr
does any one have instructions on the old style apexi AVC-R , i think the model number is 9405 its about 4 inches wide and an inch tall , it came with my z and after going to the apexi web site i still cant find a hand book on how to operate it . if i just turn the power off will that afect the running at all.thanks guys and gals :cry:
