Hi
Im new to the Z and a really daft question??
Is there a light for low petrol. If so where abouts as i havent seen it come on yet. I know you should never run on empty but just in case
Also i have forund out i have a dogey oil pressure guage. Any one knoe were i can get a sender from online??
Thanks in advance
Dave :)
there is a petrol light should be on the petrol guage, however mine has never come on yet, im not sure if its not working, but i never let it get so low to find out lol
Thats fantastic people thatnks very much :)
Ihave had a look at the petrol gauge an cannot see where the light should be?? :rolleyes:
where your tank level is on the right of the dials
Also the oil pressure gauge or temp gauge isnt very reliable, as anyone on here will tell you. Sometimes they read high pressure sometimes they read low pressure, mine does it now and then. Its not usually the pump or the sender at fault, thats why most people fit a good after market gauge
Have to say, I still haven't seen mine come on, even when the needle is right down at the 'E'
bulb probably gone easy to replace
If you have After market dial faces that stick over the original dials as i have you wont see the fuel warning light come on as they stick over it and block it out.
