upgraded injectors
hi peeps,
im looking in to up grading my injectors to keep up with my new mods!
would i have to upgrade my fuel pump aswell?
regards dan
  • Replies 41
  • Views 2k
Fuel pump is good to at least 600RWHP
It is actually much better than that BUT you have to take account of age and wear ;)
hi peeps,
regards dan
Hey Dan,
If you're looking at new injectors I can help source Nismo 550's (or larger). Don't forget to get a suitable chip as well (I've got a DTA-Motorsport 550cc manual transmision performance chip coming available for sale in a day or so). Can also source a 300 Degree fuel rail and associated fitting kit which will make fitting larger injectors a doddle (plus facilitate easy upgrade in the future).
Just planting a thought or two ... ;) LOL
Cheersio!
Dan
even if it was new you would need some serious fuel pressure for a zed pump to supply enough fuel for 600 rwhp
Hey Dan,
Cheersio!
Dan
ok cheers ive sent a pm!
what other opsions do i have except nismo 550 or are they the best opsion? deff sounds the most expensive lol
Nismos are a reputable brand and of very good quality. It'll be £545 for a set of six injectors and associated seats/gaskets.
Dan
all depends on how much power your realisticly going for, if your going for 450-500 bhp then 550's will be more than enough, if your going for more than that (which is not easy LOL) then you may want to look at the 300 degree rail or the border rail with 850cc injectors :)
ok i think 550's should do lol. is there any other brands cheaper than nismo but good enough for the job? also sounds like i wont be needing the 300 degree fuel rail either then (save some money :)) i also need prices wheres best to look??
regards dan
there is but i wouldnt go down that route!! all i can say is keep a look out for a set of second hand ones :)
For pre 94 Zeds the options for injectors are fairly limited, Nismo 555's being the most common drop in and capable of around the 500-550bhp area, price wise Dan has posted above, he can also sort you out the chip to run the injectors.
For 94 onwards, the list of injector types becomes quite extensive and often cheaper too by around 100 quid the set of 6.
The 300 degree rails on ALL zeds allow almost any injector to be used whilst at the same time addressing the 6th cylinder lack of fuel problem on the pre 94's, unlike the border kit which doesn't :)
TBH mate, just get the nismos and chip and be done with it like many many others, you will only really know when an injector has gone bad or not upto the job when it's possibly too late, so for the saving of cheaper alternatives IMO ain't worth the grief!
cheers
smithy
ok thanx for your replys! so whats the best to have once i have the injectors border kit or 300 degree fuel rail also cheapest lol
300 degree rail is the one to go for. FACT
Its certainly cheaper but be careful what you say, the 300 degree rail is quite obviously a copy of the border rail so all the crap on TT.net thats spouted is just that...crap, border are one of the most respected manufacturers of jap performance parts in japan so i doubt thats its that flawed and lets face it, most of the high performance 300zx cars in the world run the border rail ;) so its not that bad but yes its expensive but when you see one you can see where your money has gone.
As long as they have done a good job on the 300 degree rail then i see no reason why it cant perform as good as the border rail :) and as i said as long as it does perform then its a bargain at the price ;)
Mike
Just to remind you mate, you don't need any fuel rail kit, 300 degree or other if going with 555 nismos, assuming yer a pre 94 then the only benefits of fitting the rails are slightly cheaper injectors ( about 100 quid) and better fuelling to No.6, you purchase pre 94 nismos and they drop straight in.
Just one note Mike on the 300 degree rails FYI :) they were over 2 years in the making and design off, they were designed around the border kit yes just like UAS ones, thats fairly obvious, BUT they did do them so they could be used with various options of injectors and to keep the fuel flow even across the 6 cylinders and yep I believe the 300 degree were flowed against the border ones.
Considering any high powered Zed is running forged pistons and airing on the side of richness, then no real problems would actually be apparant with Border kits, that said, yes a real good piece of kit, i've sold a few in me time :)
cheers
smithy
Just be very carefull what you but second hand.
I bought 555 injectors off of a guy on this forum and two are duff. If you but S/H get them tested before you fit them as taking the plenum off again is PITA.
PS, to the guy I bought them from....If I could remember who you are I would expect some refund. I will remember one day.
No they weren't off me before anyone asks :D Anyway, duff ones are the good ones :rofl: ;)
right im a little confused now! so if i buy pre 94 spec nismo 555's i wont need a fuel rail/border kit?
can you still buy this version new? also by not having the fuel rail/border kit on my zed what problems will it cause??
regards dan
Nismo 555s will fit straight in to your fuel rail. You won't have any noticable problems unless you're running right on the limit of the 555s. The stock rail suffers with a problem of less fuel being delivered to the no 6 injector, however, unless you're running right on the limit this won't be an issue...
Just buy the pre '94 nismo 555s and be done with it. Don't forget the chip so it fuels correctly...
ok thanx for your help!
so all i got to do is find the best offer now lol
i take it the seats and gaskets dont come with the injectors either :mad: are they expensive?
Again, as per dannys post above mate, he's listed the price for you including new seals which IMO is a must, He may do you a deal on the chip required if purchasing the injectors at the same time, worth asking :)
smithy
Yep agreed DEFFO do the seals!!! Also replace the lower insulators as if these leak you will have a boost leak...
ok thanx think i would change them aswell sounds like its the safer opsion.the other thing im worried about now is will the stock internals cope with the injectors change and my previous mods. im hoping to finish with the engine once ive changed the injectors.
regards dan
What mods have you got? Sorry if this has been posted before...
