Help please.major lighting problem
Hi every one,can you help,what lights are what.The bloke l bought my 300 off had done some "improvements",and he must of moved some wires,which is head lights,spot lights and full beam,full beam don"t work at all,(not the fuse or relay),if side lights are in the bumper they to get brighter when spot lights go on,what a mess.Thanks for reading and for any help l can get.regards mick :headvswal
Is it an import?
if so, side lights and front fogs in same housing. so when you switch fogs on lights get brighter.
Check main beam bulbs, may have gone.
simple things first!
if not check main beam fuses, under bonnet on left side, dipped and other light fuses in drivers well on side.
