Engine Vibration!!!!!!!!!!!!
JUST A QUICKIE PEOPLE.
IF THE TIMING IS SET 1 OR 2 DEGREES RETARDED OF THE 15 DEGREES BTDC, WILL YOU GET A LITTLE VIBE FROM THE ENGINE UNDER BOOST THROUGH THE GEARS????
I HAD A MECHANIC SET MY TIMING TO 15 DEGREES BEFORE THE 15 DEGREES BTDC!!!!!! :headvswal
AND BOY DID SHE VIBRATE UNDER LOAD!!
CHEERS
No posts to show
