Low compression
Have just done a compression test and piston 4 is at 50 Could there be any other causes than a knackered bottom end??
- worn valve seats
- sticking valves
- head gasket leak?
there may be other possibilities....
- worn valve seats
- sticking valves
- head gasket leak?
Worn Rings or cracked broken ring lands or burnt valve
Put a very small amount of engine oil in all the cylinders and test again to see if its rings. (wet test)
