Ztech ECU
I have and upgraded ECU for my auto but don't know what it actually does. It was supplied by Ztech if that helps. Is it a Nisstek map? Anyone know? Thanks
I need to know what it does alter, ie line pressure, gear changes, road speed... Anything like that.
To my knowledge the Z tech map (i just got one to) Enables you to run 1 bar boost, increases the rev limit by 200 rpm and does away with the top speed limiter.
It's not a Nisstek map. Don't know who's they used.
Speak with John Dixon, pretty sure he at some time done Ryan's chips for him.
smithy
I did some of the more specialised ones for him. Most of the ones for stock cars were just JWT ones he did.
Is there anyway I can check?
The JWT ones will all have the same checksum, so it is usually possible to verify which are which.
Is there anyway visually?
Probably not unless they're been labelled.
will be based on a similar map to a jwt. but not the same copyright and all that shit
