555 injector
Hi, as above, I think I have a faulty one, so although I havent checked yet as I have to take plenum off if anyone has any for sale can they let me know please. Or know someone/where theere might be
Before going to the expense of buying a new injector check to see if your ones are working with either the 'screwdriver-handle in the ear' trick or get one of these:
http://cgi.ebay.co.uk/SEALEY-Car-Mechanics-Garage-Stethoscope-Brand-New_W0QQitemZ160151432247QQihZ006QQcategoryZ11704QQcmdZViewItem
try wiggling the injector connect which doing it! The dredded crusty-green-shit might be causing a bad connection.
Si.
sorry for late reply, been away. My son had a frind look at it while I was away, turns out there was a broken wire to the coil, which he fixed, and TWO injectors are faulty.
One does not work, period, and one has a very poor spray pattern.
I bought these from someone on here too.
get them reconditioned - much cheaper than forking out for new ones. AND, if you send off all 6 they'll flow test them and adjust (where possible) to match the flow rates up.
Here's a start: http://injectorcleaning.com/
Si.
Thanks WillyEd, rang them and they no longer do it, but now I will look for someone else, Cheers
