Any builders
This is my idea for a wall for the sides of my pond.
What do you reckon?
Hopefully it make sense!?
Because im building another rectangular bit on the end for plants. Sleepers wouldnt really be that good for this bit. Also im putting a water fall bit between these two.
Bricks seems the best way, I prefer the look too.
Standard brickwork requires a peer building at every 3 metres to stop central movement. It might be advised to build a peer in the centre of the 4 metre sides or set a couple of steel rods into the concrete to build around.
I dont know what a peer is? but a steel rod into the footing I can do.
Someone said about some mesh as well that you wan put in the morta to help strengthen things up?
