No Power To Boost Solenoids...Advice??
Ok as you guys know im in safety boost..............
Cant find a boost leek anywhere and used the proper tool to test.
Water temp and det sensors are fine,
All clean on the conzult (thanks topless)
Tried a spare ECU and had the same problem so not that (thanks andyP)
So...Checked the plugs for the boost solenoids and theres NO voltage to them at all, tried with the engine idling too!!!!!
Does this mean theres a prob in my loom somewhere????????????
  • Replies 29
  • Views 871
Apparently if you earth the green wire on the passenger side boost solenoid it can be a cure, you should get 12V+ when the throttle is open to both solenoid's so if you're getting no voltage then it would point to a break in the wiring / circuit somewhere... For testing purposes use a paperclip and wedge into the green pin and solder tthe other side of the paerclip to a wire and earth to the body, see if it makes any difference, if not just install the aftermarketboost controller...
Ok, thanks. Going to go for the boost controller i think but might try that this weekend just to be 100% its the loom thats the problem..
Ive tried earthing the green wire and re setting the ecu but still in safety boost!!!!!!
Very frustrating
