In memory of Mandy
safe boost?
My car has an apexi boost contoller, its boosting at 0.6 bar at the moment, what will i be able to increase it to safely on a standard intercooler?
Stock is 9.5psi / 0.66 bar. Do you have the ECU chipped.....if not then I would'nt recomend going over 12psi/ 0.8 bar if you do have it chipped then most run at around 14psi/1.0 bar
While the intercoolers are a restriction, its actually the Injectors that are the biggest limit.
I know its got a john dixson chip, dunno if that helps. I want to run it at 1 bar but want to make sure its safe first
I always use tesco 99 octane in all my cars
