codes
guess thats another question no zx owner knows the answer too then.
i must have a knack for asking the unknown
Pulling codes refers to running diagnostic checks. This can be done via the potentiometer on the ECU, shorting out two pins on the diagnostic DDL in the driver's footwell or much easier by using a ConZult diagnostic kit.
When interrogating the ECU it will present stored fault "codes". A code "55" means no faults are stored. Any other code, or combination of codes, needs to be looked at.
If you do a search for "diagnostics" and "fault codes" you're sure to find a list detailing the codes and what they mean.
Dan
