Apexi multichecker
Anybody got a pic of how to wire this into the ECU on a z32? My instructions are in japanese :(
White = 27 Mass Air Flow Sensor MAF
Brown = 42 Camshaft Position Signal (Down as Crank 1 sensor in manual)
Pink = 1 Ignition 1 Coil #1 (No 1 Ignition Signal in manual)
Blue = 41 Camshaft Position Reference Signal (Crank 120/180 signal in manual
Orange = 101 Injector 1
Black = 26 Mass Air Flow Sensor Ground (Ground in manual)
Red = 59 Power for ECM (IG Power in manual)
Green = 53 Vehicle Speed
Grey = Only used if removing speed limiter
Light Blue = Not Used
Ediited to correct
sounds about right to me compared to other electronic devices but couldnt say for certain.
Is that how many wires need to be connected then in total, 10?
Where are you going to mount yours. Would it be possible to post up some pictures of the instal and how the fitting went and what you reckon of the unit when you have got it all plumbed in and tried it out?
