auto box
Hi first post and already need help got a 300 with broken box slips in D+R but drives in and out of garage not tried it at any distance
but when its hot slips more than a bloke with a slippy thing :( anyhoo
where is the best place to get a recon or good second hand box from
or what could be wrong with the one in there tried the search thingy
could not find a fix for my problem
Hi, best thing to do is try all the cheap options first like changing the fliud & cleaning the filter which if blocked can cause similar problems, if that doesnt work then possibly indicates the clutch packs are worn which means time for a rebuild or replacement unit, also if your car is a jspec best to buy a aftermarket oil cooler as that is far superior & provides better cooling then stock one which is built in the radiator
is your 300zx a tt or na ?? as i have a good low mileage autobox + tc available for a tt can send you pics via email
thanks for the reply its a tt fairlady 1990
well as i have mentioned if you end up needing a replacement box i have one with torque converter, can send you pics/details via email
Technical Automatic Services Ltd
Phone : (01206) 386303
I had my zeds autobox rebuilt here, They can rebuild to stock or performance. I also had my Trans am autobox done and thats now pushing out 500bhp with no problems.
In truth i cant remember as it was about two years ago but gearbox still going strong with no probs, Will try and dig out the receipts.
  • 3 weeks later...
Try MJS in Ipswich, they can supply and fit a recon box or if you can get a second hand one from AndyZ they will fit that for you.
Just had mine done by http://vmtp.co.uk/ in the Mildands.
Cost 1500 but with tow in and out and extra cooler as recommended above, ended up at 2000. Its going ok, and i'm happy
Other option was find a used item for 500ish, extra to fit and take a chance
David
If you had of contacted us we supply and fit second hand ones for £600 with 3 months warranty ! never mind i was on holiday i spose.
