apexi boost controller can anyone help me
i have a apexi boost controller installed, 2day going to work i had a long strech of road empty in front of me so decided to test what i could get out of it, i floord it in 3rd and the throtl was at 65% on apexi unit with full foot down thats not right is it? and 0.61 cm2/mm is this good what bar is that? i have a standrd chip at mo as my other ecu messed up i need to get the chip soldered in to my new ecu, but for mean time wanted to see if tubs and evrythings upto scratch! any help would be help full!!
any one?
I wouldn't try and run higher boost or mess about with a boost controller on a standard chip, you'll destroy your engine.
The car will only boost and fuel to stoc chip settings. I would say you have the boost controller set too high for the stoc chip and thats why you have a reading of 65% on the controller even though the car is on full boost which equates to 65% of the setting you have the controller set at.
no the boost controller is on setting off its not set thats what im saying.
O right. You could be in safety boost then, which is the stock setting about 7psi if the controller is off
Don't all ebc's put your car in safty boost, I know mine does profec EO1
what he said!
Sounds about right to me. If the controller is set to OFF, you should just get normal boost, which if I remember correctly can go up to about 9 to 9.5 psi.
I thought the unit of measurement on the AVC-R was kg/cm², and 1 kg/cm² equates to 14.22 psi. And so 0.61 kg/cm² equates to 8.67 psi. Pretty close to standard boost, which is correct if you haven't had the car chipped yet. I wish my car would do the same when set to OFF. :(
TBH mate seeing as yer in the Northwest, when yer happy your running what chip etc you want, pop along to either RC developments or DP Motorsport both in Warrington and have them do it, i did that and it was done in like 30mins with no messing, once done, i ain't touched it. These guys intsall and set up AVC-R's all the time so know how to do it properly.
smithy
smithy
whats the charge for setup by them? and any contact numbers? also smithy do u have pvc valves? if so can u get you payment details etc to me so i can pay u asap as i need to change mine. tnx
loll well i did have my original ecu chipped but had a rust prob on ecu so messed up big time was making car do sunny things, i have a jwt chip which im going to get installed soon but cant seem to find neone round here whos gona do a proper job, current ecu has a resitriction car struggles to get over 100mph also rpm wil only go till 6000 p*sses me off.
also if its close to stock boost there must be a leak if it dont get bang on stock boost figures lolll being greedy now...
Hi mate it was quite some time ago i used either DP or RC, however as long as the AVC-R is in the car and working in a fashion, then 40 bucks should see it done, it don't take em long, however am sure they can advise over the phone, just make sure you state it is already fitted and working.
http://www.rcdevelopments.com/portal/
01925 445174 DP Motorsport
As for the valves an hoses, mike feeney of MJP in the traders section is best for these and usually carries stock mate.
cheers
smithy
tnx smithy been ringing mjp but no luck either no one answers or straight to answer msg!!!
