Two questions..
First one... Is there anyway to get the boost to build up faster with the apexi avcr boost controller? I don't get full 0.9 bar before around 4000rpm.
Second one... I've got a rattle from the engine. Only done this from the engine.. Comes when I rev the car and suddenly goes of the throttle cable. :shock: than disapears again. :confused: Not enough rev and hard enogh to make the dump valve make any sound though. HELP
De cat it spose to help quicken spool times up, I guess an induction kit may help a little too.
Second question, im not really sure what your trying to say?
check the settings on the boost controller as it is probably set that way !
the noise could be anything without you describing it more ?
I just followed the info on twinturbo.net on the apexi avcr setup. (self learning mode) When is the car supposed to have full boost??
The rattle. Not easy to describe. Metalic rattle. seems to come from the top of the engine. Difficult to pin point.. from the middle of the enigne maybe.. seems like it is all around the engine... Also got a rattle when i'm nearing 7000rpm. Had a mechanig hear at it and he didn't know what it was.
7000 rpm :shock: i would,nt go there to often mate with a top end rattle
